I wonder that there is an easy way to receive a notification when a new project is created. I do some research about
sql and such notification but because I' not sql expert it seems too complicated for me.
Any help please.
Any help please.
Jeff -
Good idea. If a template is used to create the project, you could creat a dummy document at the same time and use the document to trigger a dispatch action to send the notification, then use dispatch to delete the dummy document.
Joy
Hello Joy
First of all I must mention that we use PDMWE 2008 sp 5.0
I try your solution but there are some limitation. I can't retrive, by a dispatch acction, the name of new folder (project) so I can't delete the new created file. Also in the message I can not insert user variables.
Now I receive a message and I must find the new project by date.
Jeff -
Joy
