Error executing the command 'D:\Program Files\Common Files\eDrawings2009\EModelViewer.exe "Then File name and location".
Anytime I click on View/Markup...
Any thoughts?
Nic
Any thoughts?
Nic
Nicole,
Try playing around with the user-settings under PDM Administration. (You need admin rights)
Select the User, probably yourself, right click and select settings, then under viewer select the Emodel viewer (with proper location and argument)
see pic...
Maybe the location of the Emodel Viewer is wrong.
Hope this helps,
Mark
It worked fine when we moved to 2010 for EPDM and SW but problem only showed up when moved to Win7
See attached image for my viewers screen shot
Nicole,
Are you using E-Drawings 2010?
Because if you have SW2010 files and you still have E-Drawings 2009 you will get an error message as well.
You need E-Drawings 2010 to see SW2010 files.
