Does anyone know a way to change the default Counterbore depth in Hole Wizard so we dont have to change it everytime in options? I thought it might be in the swbrower.mdb file but I couldn’t find it in there or I can’t figure out the name in the database. If anyone has any ideas I would appreciate it.
Scott Schueler
Hello Scott,
You can change that default in the swbrower.mdb file. Depending on the standard you are using, for Ansi Inch it should be AL_DATA_SHSCREW, and for Ansi Metric it should be AM_DATA_BS_SHCSCREW. I do not know why the title is different but it is. In those chart you will see a column called CBORE_DEPTH. Be sure you make a backup copy beffore changing anything.
