Has anyone ever had a problem where you can't delete an empty folder.
This folder has been created in our vault and it has been used before (it contained files) but now it is empty.
When I try to delete this folder, I get a pop-up window stating that the folder contains hidden files you may not delete.
I am the administrator and I am almost alowed to do anything including delete etc.
The person who created this folder insists that they don't have anything local in that folder.
Could it be that the PDM system still has some hidden files in this folder and it's blocking me from deleting?
Is there a way to search for that user who has local files in this folder?
Thanks, Mark
Hello Mark,
had the same problem, empty folder, no files, also no hidden files. I try many things - rename etc. but nothing helps me. So i looked at the next service pack and see that the problem is solved. We changed the version from EPDM 2010 SP 0 to SP2. Then deleting empty folders was no problem.
Greetings
Chris
