I did the following steps:
Close the sketch and do the following:
Click the Design Library tab to open the Task Pane.
Click *the pin* to pin down the Task Pane, and select Design Library .
Browse to folder where you want to add the library feature.
Press Ctrl and in the FeatureManager design tree, select the features you want to save as a library feature.
[Do not include the base feature as a part of the library feature. If you include the base feature, the base will be part of the library feature (*.sldlfp) when you drag it to a model.]
Hold down Ctrl, and drag the features to the lower panel of the Task Pane.
I also tried:
1. Click the Design Library tab
2. Click 'Add to Library'
3. Select the feature to add
4. Name the feature
5. Click the green check mark
Depending on which folder I choose to save the file in I either get this error:
'Failed to save file'
or
it appears to save, but there is no feature in the library files.
I did find a copy of the sldflp file located here:
C:\Program Files\SolidWorks Corp\SolidWorks\Toolbox
How do I move it so it shows up inn the task pane?
Any suggestions?
