Does anyone know of a workaround for not being able to revolve a 3D sketch? Projecting that 3D sketch onto a plane is not a valid solution because it won't re-create the same surface.
Sam
Sam
Actually, I'm more interested in revolving a 2D sketch around an axis that is not in the same plane. I'd like to revolve Sketch 1 around Axis 1 in the attached file....
I'm not so interested in the revolved surface, but in the intersection of the revolved surface and Plane 1.
Thoughts?
Thanks!
Sam
Nevermind. I solved it using a 3D sketch and a Surface-Sweep. I've attached the soln in case anyone else needs it.
Sam
I've done it this way before:
p.s. Sorry that I can not look at your example due to being a version behind.
