Is there a (good) way to render a SolidWorks assembly to a file so that when I import it into a graphics program (Corel) it comes in at 1 to 1?
I have a model that is approximately 10" x 20". I am rendering a top view in PhotoWorks (render to file) and want to place the rendered image over the top of an imported 1 to 1 dxf of a drawing. The problem is that I haven't found a combination of settings that allow me to export the rendered image so that when I import it into Corel it comes in at 1 to 1. It always is much larger than 1 to 1. We need at least 800 dpi resolution for our final graphic output.
I'm rendering to file as a *.tga so that there is no background saved with the file.
Thanks in advance for the help.
My first question is: why are you using Corel? Can't you just scale your render after you add over the .dxf?
Alternatively, you could import the .dxf as a sketch in SW and use the render as a sketch picture and resize it there.
