Hi all,
Can anyone help with the following VBA macro code? I need to get the center of area of some sketch geometry in a sketch. GetSectionProperties2 method of ModelDocExtension looks to be the call I'm after, but I'm sure I'm not building the "section" input correctly and there isn't much info in the API help. When I run the macro, the returned value of the first array element is 1 = "invalid input" according to the API help. All other values in the returned array are zero.
FYI, I was hoping to select a single boundary of lines, arcs, etc. from a more complicated sketch and get just the center of area of the selected boundary.
Dim model As ModelDoc2
Set model = swApp.ActiveDoc
Dim selmgr As SelectionMgr
Set selmgr = model.SelectionManager
Dim sections As Variant
Dim tmp() As Object
ReDim tmp(selmgr.GetSelectedObjectCount - 1)
For i = 1 To selmgr.GetSelectedObjectCount
Set tmp(i - 1) = selmgr.GetSelectedObject(i)
Next i
Dim values As Variant
values = model.Extension.GetSectionProperties2(tmp)
