is there a way to flatten this part? i need to flatten it so i can add holes in it on a flat plane.
Greg,
Try this way- start with just an arc(see doc1)
After desired sketch select base flange(sheet metal feature) see doc2.
Set parameters(k factor=.428"),thickness(t=12mm in your case)
After setting - click ok.
From tool bar(must add to tool bar) select flatten - will give you flat.
In order to add holes in flat you have to unfold first,add holes,fold.
Sam
Greg,
Here is your flat "capable" part
If our want the flat pattern, suppress Process-Bend1 in the Feature tree.
Mark
