I have an issue here at work where I created parts and drawings using the standard SW templates. I didn't realize that we have setup customized templates using our drafting standards on site. The parts are fairly complex and to redraw them is not really an option. Is there any way to reapply the templates to the existing files instead of redrawing everythign?
I have tried saving the model as an IGS and re-opening it using feature recognition inside the new template. The issue I ran into is that the dimensioning standard does not follow our template. Instead of "ANSI" it lists "ISO" after feature recognition. I do not know enough about SW settings or our standards to go through and check everything so, again, it would be very helpful to have a "drag and drop" fix to this issue.
Thank you for your help in advance.
For part document settings you can open a new file that has the settings you want and save those out to a Drafting Standard file. Then open each part you want to bring up to date and load the standard file.
For drawings you need to do those same steps but then you also need to reload the sheet format from the sheet properties window with the sheet format you want.
if you need more detail let me know.
