I have experienced a similar issue, but I figured out a fix.
I was not able to open your zip...internal security settings... so
I don't know what type of animation you're trying to create. I have
been doing simple explodes...
The way to do this, is to first try to anticipate how far
away the viewer will need to be in order to see the entire
production. Then name a view : "explode".
I zoom in to select parts to move, then reset to the explode
view, so that I don't move the parts outside of my production view
window.
Good Luck !
I am trying to animate the assembly shown in attached JPG
, I zoom to fit in order to see how the assembly explodes and
collapses. As soon I play animation, the part zooms in and hides
the most of its parts (see attached JPG),
I am not able to see how it is animated. Please help.
The way to do this, is to first try to anticipate how far away the viewer will need to be in order to see the entire production. Then name a view : "explode".
I zoom in to select parts to move, then reset to the explode view, so that I don't move the parts outside of my production view window.
Good Luck !
