Dual-dimensioned hole with tolerance - bug?
Question asked by John Manly on Mar 8, 2010
Latest reply on Mar 18, 2010 by Glenn Douglas
Hi all:
In SW2009, I occasionally have a hole made with the hole wizard, and use dual dimensions (mm primary, in secondary) with a tolerance.  I can select the precision of the dual units, but it applies to both the hole diameter and hole depth.  If I use the Callout Value dropdown to specify that I only want the tolerance to apply to either the diameter or the depth, it behaves as expected for the primary units, but the secondary unit precision is overriden by the selection under Dual Dimension.
I assume this is a bug?  Is it fixed in 2010?  Is there a workaround other than manually editing the depth value (making it non-associative)?
John.
