Sorry I havent responded its been crazy busy here. I was not able to get this iges to convert properly even after changing the settings around. I normally request step files but for some reason this one was sent as an Iges. I ended up just redrawing the part.
I want to thank you for writing the Solidworks Bible. I have been using Inventor for the last 5 years until our shop went under due to the depression. I was hired on at a company that uses Solidworks and your book saved me for sure. Thank you very much.
Matt,
It opens in 2010 after fiddling with some options. go to File Open, then change the file type to IGES, then click the Options button, (you have to do it in that order), then turn off the Free Point/curve Entities.
Then try the import again, using the Open dialog rather than drag and drop.
