Does anyone use half shears for precise locating two pieces of sheet metal to be joined.
How do you create them?
How do sheet metal shops recognize the feature in your files to indicate what punch to use to create the feature during punch.
-Mel-
I've usually done it by cutting out the shape of the punch, and then extruding the same sketch "offset" from the sketch plane (top of extrude menu) by the distance equal to the depth/height of the half shear.
Features like this are typically Datum features (or at least they should be) so they get dimensioned on our print, and the sheet metal shop would get the shape and location detail from the print.
Maybe not the "most correct" way, but no issues so far, at least none that have been communicated back to me.
