Electrical Connectors & Start Route
Discussion created by Guest on Mar 10, 2006
When I bring an electrical connector into my assembly it doesn't give the start route dialog box, and won't start a route. I slowly discovered that the connector being brought in from Design Library CANNOT have multiple CP points. If there is more than 1 CP it won't start a new route when bringing the connector in from the Design Library. If I edit the connector and remove all but one CP then when I bring the connector in, it will start a new route. Reading thru the Help section on Electrical connectors it seems to indicate that Mulitiple CP can be used, have I missed something here? Anyone else run into this? Now that I'm aware of this I guess it isn't a big problem, but have spent a couple of days trying to figure it why I can't get a route started!!
