We have a couple of interns working on Rhino designing a control counsol for us. They have designed a control paddle that needs to be molded. I can import the iges file into SW and make a solid with no problems. The vendor would now like us to give them a surface model so they can split it and create the mold. I tried shelling the model but that was not what they wanted. Apparently he wants just a surface model and both he and I are unable to create one. -I have never worked with surfaces before, Just solids. SW help tells me how to use the Surface Extraction Property Manager....but I can't find it on my machine to attempt using it. I also am not sure that is the best method to use.
Can someone suggest how to create a surface model, either from importing the Rhino surface, or by extracting a surface from the SW solid model?
Thank you
Jim S
Is he using SolidWorks as well?
If he is using SolidWorks, and you are sending him a .sldprt file:
1. Select the Body in the Body Folder in the Feature Tree. Sometimes this is automatically set to hide. So go to Tools>Options>System Options>Feature Tree. There will be a list of options to either hide, show, or "automatic". Make sure the one called "Solid Bodies" is set to show.
Do not select the body any other way besides selecting it in the feature manager tree, inside the "Solid Bodies" folder.
2. Use the Insert>Surface>Offset Surface tool. This will offset all the surfaces of that body. Set the offset distance to zero.
3. This will create a second body, which is a surface body. Make sure to either "Delete Body" the solid, or just hide it (from the body folder in the Feature Manager Tree).
If he is NOT using Solidworks:
When you export the part file, (to IGES or STEP), you can follow these steps:
1. Go to File>Save As... select whatever format you are using to export. Then click on Options... in the lower right.
2. There should be options. browse through them to find the one that says either "solid body" or "surface body". They will be called different things for different types, so use your intuition.
