3 Replies Latest reply on Mar 3, 2010 8:10 AM by Mark Kaiser
    brake lines around dimensions
    Mark Greenwell
      Hi
      In the attached PDF file I have a vertical dimension (1136) which is overlapped by two diagonal dimensions.
      When I was using Inventor the diagonal lines would automatically brake around the vertical dimension text.
      Is this not possible in SolidWorks.
      I know I could move the vertical dimension, this drg was used as an example.
      Mark (SolidWorks 2010 SP 2.1)
