I've got a component part with 8 configs in a DT. The DT has two columns each controlling a dimension. I am editing these dimensions in the assembly by double clicking the component and then double clicking the dimension. Usually everything works as it should and the new dimension is applied to only that component configuration. Sometimes, though, the dimensions in all the configs are changed to that value, which I really don't want.
I've tried to get something reproducable. I've checked that the dim properties are config specific. I've deleted the DT and remade it. I've I made a pack'n'go to send to my VAR, but it did not recreate the error, at least right away. I rebooted completely and for awhile I thought it was fixed, even got most of the table filled out, but now one column is filled with identical values. I now think I should reboot, open the pack'n'go, and work it awhile to see if it fails.
Anyone else see something like this? Know anything to try? Just checking before I waste a lot of time trying to track this down.
Dwight
- more -
Forget the design table. I've got the problem even with the DT deleted. I'm going to remake the component and hope it all goes away. If I've got a spare moment sometime I'll see if the pack'n'go is broken, and if so I'll send it in.
