Re: 2 questions 1 macro
AMCBridge eXperts Feb 28, 2010 7:40 AM (in response to Aaron Larson)Yes, it is possible.
Please attach the original macro and I'll help you to update it.
Aaron Larson Mar 1, 2010 8:52 AM (in response to AMCBridge eXperts)Not sure which question you were answering (hopefully both). Below is the bounding box macro (I've commented out some lines I don't want):
' * This macro gets the bounding box dimensions for the config specific
' * model and adds a small amount to it. This amount can be changed
' * by modifying the "AddFactor" value below. It checks to make sure
' * you have a proper document open. It checks & utilizes the user units.
' * It will add 3 separate properties or combine them all into one property.
' * It will optionally draw a 3D sketch for you.
' * Modified by Wayne Tiffany, Oct 12, 2004
' * Updated 10/15/04
' * Original few lines of demo code by someone else (unknown). Fraction
' * converter original code from rocheey. 3D sketch original code from
' * SW help.
' **********************************************************************Dim swApp As SldWorks.SldWorks
Dim Part As SldWorks.ModelDoc2
Dim Height As Variant
Dim Width As Variant
Dim Length As Variant
Dim Corners As Variant
Dim retval As Boolean
Dim UserUnits As Variant
Dim ConvFactor As Double
Dim AddFactor As Double
Dim ConfigName As String
Dim SwConfig As SldWorks.Configuration
Dim MsgResponse As Integer
Dim swSketchPt(8) As SldWorks.SketchPoint
Dim swSketchSeg(12) As SldWorks.SketchSegmentConst swDocPart = 1
Const swDocASSEMBLY = 2'Enum swLengthUnit_e
Const swMM = 0
Const swCM = 1
Const swMETER = 2
Const swINCHES = 3
Const swFEET = 4
Const swFEETINCHES = 5
Const swANGSTROM = 6
Const swNANOMETER = 7
Const swMICRON = 8
Const swMIL = 9
Const swUIN = 10'Enum swFractionDisplay_e
Const swNONE = 0
Const swDECIMAL = 1
Const swFRACTION = 2Function DecimalToFeetInches(DecimalLength As Variant, Denominator As Integer) As String
' converts decimal inches to feet/inches/fractions
Dim intFeet As Integer
Dim intInches As Integer
Dim intFractions As Integer
Dim FractToDecimal As Double
Dim remainder As Double
Dim tmpVal As Double
' compute whole feet
intFeet = Int(DecimalLength / 12)
remainder = DecimalLength - (intFeet * 12)
tmpVal = CDbl(Denominator)' compute whole inches
intInches = Int(remainder)
remainder = remainder - intInches
' compute fractional inches & check for division by zero
If Not (remainder = 0) Then
If Not (Denominator = 0) Then
FractToDecimal = 1 / tmpVal
If FractToDecimal > 0 Then
intFractions = Int(remainder / FractToDecimal)
If (remainder / FractToDecimal) - intFractions > 0 Then ' Round up so bounding box is always larger.
intFractions = intFractions + 1
'Debug.Print "Feet = " & intFeet & ", Inches = " & intInches & ", Numerator = " & intFractions & ", Denominator = " & FractToDecimal
Call FractUp(intFeet, intInches, intFractions, Denominator) ' Simplify up & down
' format output
DecimalToFeetInches = LTrim$(Str$(intFeet)) & "'-"
DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intInches))
If intFractions > 0 Then
DecimalToFeetInches = DecimalToFeetInches & " "
DecimalToFeetInches = DecimalToFeetInches & LTrim$(Str$(intFractions))
DecimalToFeetInches = DecimalToFeetInches & "\" & LTrim$(Str$(Denominator))
DecimalToFeetInches = DecimalToFeetInches & Chr$(34)
'Debug.Print DecimalToFeetInchesEnd Function
Function FractUp(InputFt As Integer, InputInch As Integer, InputNum As Integer, InputDenom As Integer)
'Debug.Print InputFt, InputInch, InputNum, InputDenom
' Simplify the fractions, Example: 6/8" becomes 3/4"
While InputNum Mod 2 = 0 And InputDenom Mod 2 = 0
InputNum = InputNum / 2
InputDenom = InputDenom / 2
Wend
' See if we now have a full inch or 12 inches. If so, bump stuff up
If InputDenom = 1 Then ' Full inch
InputInch = InputInch + 1
InputNum = 0
If InputInch = 12 Then ' Full foot
InputFt = InputFt + 1
InputInch = 0
End FunctionFunction GetCurrentConfigName()
Set SwConfig = Part.GetActiveConfiguration ' See what config we are now on & set the variable
GetCurrentConfigName = Part.GetActiveConfiguration.Name ' Return the nameEnd Function
Sub DrawBox()
Part.Insert3DSketch2 True
Part.SetAddToDB True
Part.SetDisplayWhenAdded False'Draw points at each corner of bounding box
Set swSketchPt(0) = Part.CreatePoint2(Corners(3), Corners(1), Corners(5))
Set swSketchPt(1) = Part.CreatePoint2(Corners(0), Corners(1), Corners(5))
Set swSketchPt(2) = Part.CreatePoint2(Corners(0), Corners(1), Corners(2))
Set swSketchPt(3) = Part.CreatePoint2(Corners(3), Corners(1), Corners(2))
Set swSketchPt(4) = Part.CreatePoint2(Corners(3), Corners(4), Corners(5))
Set swSketchPt(5) = Part.CreatePoint2(Corners(0), Corners(4), Corners(5))
Set swSketchPt(6) = Part.CreatePoint2(Corners(0), Corners(4), Corners(2))
Set swSketchPt(7) = Part.CreatePoint2(Corners(3), Corners(4), Corners(2))
' Now draw bounding box
Set swSketchSeg(0) = Part.CreateLine2(swSketchPt(0).X, swSketchPt(0).Y, swSketchPt(0).Z, swSketchPt(1).X, swSketchPt(1).Y, swSketchPt(1).Z)
Set swSketchSeg(1) = Part.CreateLine2(swSketchPt(1).X, swSketchPt(1).Y, swSketchPt(1).Z, swSketchPt(2).X, swSketchPt(2).Y, swSketchPt(2).Z)
Set swSketchSeg(2) = Part.CreateLine2(swSketchPt(2).X, swSketchPt(2).Y, swSketchPt(2).Z, swSketchPt(3).X, swSketchPt(3).Y, swSketchPt(3).Z)
Set swSketchSeg(3) = Part.CreateLine2(swSketchPt(3).X, swSketchPt(3).Y, swSketchPt(3).Z, swSketchPt(0).X, swSketchPt(0).Y, swSketchPt(0).Z)
Set swSketchSeg(4) = Part.CreateLine2(swSketchPt(0).X, swSketchPt(0).Y, swSketchPt(0).Z, swSketchPt(4).X, swSketchPt(4).Y, swSketchPt(4).Z)
Set swSketchSeg(5) = Part.CreateLine2(swSketchPt(1).X, swSketchPt(1).Y, swSketchPt(1).Z, swSketchPt(5).X, swSketchPt(5).Y, swSketchPt(5).Z)
Set swSketchSeg(6) = Part.CreateLine2(swSketchPt(2).X, swSketchPt(2).Y, swSketchPt(2).Z, swSketchPt(6).X, swSketchPt(6).Y, swSketchPt(6).Z)
Set swSketchSeg(7) = Part.CreateLine2(swSketchPt(3).X, swSketchPt(3).Y, swSketchPt(3).Z, swSketchPt(7).X, swSketchPt(7).Y, swSketchPt(7).Z)
Set swSketchSeg(8) = Part.CreateLine2(swSketchPt(4).X, swSketchPt(4).Y, swSketchPt(4).Z, swSketchPt(5).X, swSketchPt(5).Y, swSketchPt(5).Z)
Set swSketchSeg(9) = Part.CreateLine2(swSketchPt(5).X, swSketchPt(5).Y, swSketchPt(5).Z, swSketchPt(6).X, swSketchPt(6).Y, swSketchPt(6).Z)
Set swSketchSeg(10) = Part.CreateLine2(swSketchPt(6).X, swSketchPt(6).Y, swSketchPt(6).Z, swSketchPt(7).X, swSketchPt(7).Y, swSketchPt(7).Z)
Set swSketchSeg(11) = Part.CreateLine2(swSketchPt(7).X, swSketchPt(7).Y, swSketchPt(7).Z, swSketchPt(4).X, swSketchPt(4).Y, swSketchPt(4).Z)Part.SetDisplayWhenAdded True
Part.SetAddToDB False
Part.Insert3DSketch2 TrueEnd Sub
Sub Main()
AddFactor = 0 ' This is the amount added - change to suit
Set Part = swApp.ActiveDocIf Part Is Nothing Then ' Did we get anything?
MsgBox "You need to have a part or assy open at this point." & Chr$(13) & Chr$(10) _
& Chr$(10) & "Open one and try again."
Exit Sub
End IfIf (Part.GetType = swDocPart) Then
Corners = Part.GetPartBox(True) ' True comes back as system units - meters
ElseIf Part.GetType = swDocASSEMBLY Then ' Units will come back as meters
Corners = Part.GetBox(0)
Else
MsgBox "This macro is only useful with a part or assy." & Chr$(13) & Chr$(10) & "Open one of those and try again."
Exit Sub
End IfUserUnits = Part.GetUnits()
'Debug.Print "LengthUnit = " & UserUnits(0)
'Debug.Print "Fraction Base = " & UserUnits(1)
'Debug.Print "FractionDenominator = " & UserUnits(2)
'Debug.Print "SignificantDigits = " & UserUnits(3)
'Debug.Print "RoundToFraction = " & UserUnits(4)
Select Case Part.GetUnits(0)
Case swMM
ConvFactor = 1 * 1000
Case swCM
Case swMETER
ConvFactor = 1
Case swINCHES
ConvFactor = 1 / 0.0254
Case swFEET
ConvFactor = 1 / (0.0254 * 12)
Case swFEETINCHES
ConvFactor = 1 / 0.0254 ' Pass inches through
Case swANGSTROM
ConvFactor = 10000000000#
Case swNANOMETER
Case swMICRON
Case swMIL
ConvFactor = (1 / 0.0254) * 1000
Case swUIN
ConvFactor = (1 / 0.0254) * 1000000
End SelectHeight = Round((Abs(Corners(4) - Corners(1)) * ConvFactor) + AddFactor, UserUnits(3)) ' Z axis
Width = Round((Abs(Corners(5) - Corners(2)) * ConvFactor) + AddFactor, UserUnits(3)) ' Y axis
Length = Round((Abs(Corners(3) - Corners(0)) * ConvFactor) + AddFactor, UserUnits(3)) ' X axis
'Debug.Print Height & " x " & Width & " x " & Length' Check for either (Feet-Inches OR Inches) AND fractions. If so, return Ft-In
If (UserUnits(0) = 5 Or UserUnits(0) = 3) And UserUnits(1) = 2 Then
Height = DecimalToFeetInches(Height, Val(UserUnits(2)))
Width = DecimalToFeetInches(Width, Val(UserUnits(2)))
Length = DecimalToFeetInches(Length, Val(UserUnits(2)))
'Debug.Print Height & " x " & Width & " x " & LengthConfigName = GetCurrentConfigName() ' See what config we are now on
' MsgBoxMsg = "The default for this program is to combine the 3 values into one property." & Chr$(13) & Chr$(10) _
' & "Do you want to keep it this way?" & Chr$(13) & Chr$(10) _
' & Chr$(10) & "(Clicking the No button will add 3 separate properties.)"' MsgResponse = MsgBox(MsgBoxMsg, vbInformation + vbYesNoCancel)
' If MsgResponse = vbYes Then ' One property
retval = Part.DeleteCustomInfo2(ConfigName, "Finished Size") 'Remove existing properties
retval = Part.AddCustomInfo3(ConfigName, "Finished Size", swCustomInfoText, _
Height & " x " & Width & " x " & Length) 'Add latest values
' ElseIf MsgResponse = vbNo Then ' 3 properties
' retval = Part.DeleteCustomInfo2(ConfigName, "Height")
' retval = Part.DeleteCustomInfo2(ConfigName, "Width")
' retval = Part.DeleteCustomInfo2(ConfigName, "Length")
'Add latest values
' retval = Part.AddCustomInfo3(ConfigName, "Height", swCustomInfoNumber, Height)
' retval = Part.AddCustomInfo3(ConfigName, "Width", swCustomInfoNumber, Width)
' retval = Part.AddCustomInfo3(ConfigName, "Length", swCustomInfoNumber, Length)
' Else
Exit Sub
' End If' MsgBoxMsg = "Do you want to draw a 3D sketch that represents the bounding box?" & Chr$(13) & Chr$(10) _
& "This is a good way to visualize the dimensions."' MsgResponse = MsgBox(MsgBoxMsg, vbInformation + vbYesNo)
' If MsgResponse = vbYes Then Call DrawBox
Aaron Larson Mar 1, 2010 8:54 AM (in response to AMCBridge eXperts)Here is the macro for which I'd like to insert the BB macro. You can see it at the bottom of the macro - it is currently commented out.
Option Explicit
Dim swApp As SldWorks.SldWorksSub main()
Dim swModel As ModelDoc2Dim vComps As Variant
Dim i As Integer
Set swModel = swApp.ActiveDocupdateProperty swModel
If swModel.GetType = swDocASSEMBLY Then
Set swAssy = swModel
vComps = swAssy.GetComponents(False)
For i = 0 To UBound(vComps)
Set swComp = vComps(i)
If swComp.GetSuppression = swComponentFullyResolved Then
Set swModel = swComp.GetModelDoc2
Else
Next i
End SubFunction updateProperty(swModel As SldWorks.ModelDoc2) As Boolean
Dim cpm As CustomPropertyManager
Dim path As String, filename As String, GenericDescription As String
Dim DescVal As String
Dim RetVal As Boolean'Sets Generic Description Property to Filename w/TN parsed
Set cpm = swModel.Extension.CustomPropertyManager("")
'gets pathname
path = swModel.GetPathName
filename = Mid$(path, InStrRev(path, "\") + 1) ' With extension
filename = Left$(filename, InStrRev(filename, ".") - 1) ' Remove extension
'Strips T/N if "T" is prefix
If InStr(Left(filename, 1), "t") = True Then
GenericDescription = UCase(Right(filename, Len(filename) - 7))
Else
'Strips T/N if no "T" previx
GenericDescription = UCase(Right(filename, Len(filename) - 6))
End If'Replaces underscores with spaces
GenericDescription = Replace(GenericDescription, "_", " ")'If no prop "GenericDescription" exists--> adds it with GenericDescription
cpm.Add2 "GenericDescription", swCustomInfoText, GenericDescription
'If "GenericDescription" already exists--> changes value to GenericDescription
cpm.Set "GenericDescription", GenericDescription'Adds concantenated "Description Property"
DescVal = "$PRP:""GenericDescription"" $PRP:""ConfigDescription"""
cpm.Add2 "Description", swCustomInfoText, DescVal
cpm.Set "Description", DescValRetVal = swModel.DeleteCustomInfo2("", "Material")
RetVal = swModel.AddCustomInfo2("Material", 30, """SW-Material@FileName.SLDPRT""")
' RetVal = swApp.RunMacro("I:\ME\Tooling Standards\Solidworks\Macros\BoundingBox.swp", "BoundingBoxCode", "Main")End Function
AMCBridge eXperts Mar 8, 2010 1:52 PM (in response to Aaron Larson)Excuse me for the delayed responce.
It seems your first issue is resolved with the last macro. As I can see you already traverses all the components within the assembly and run the BB macro. Isn't it?
As for your second issue. You could get the decimal places number using the following method:
IModelDocExtension::GetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingLinearDimPrecision, swUserPreferenceOption_e.swDetailingDimension)
Next add required number of '0' to your value which should go to Custom Properties.
Aaron Larson Mar 10, 2010 10:18 AM (in response to AMCBridge eXperts)I believe what is happening in the macro is that during the traversing, IF the model is fully resolved it calls the "updateProperty" function. The BB macro call is the last line of that function. Wouldln't the BB macro then get called inside that function? I have also tried calling the BB macro directly in the traversing IF statement and that doesn't work either.
Regarding the decimal places - I don't think I'm experienced enough to know where to put that snippet or how it functions. Any help would be appreciated. When you say "Next add required number of '0' to your value which should go to Custom Properties" you mean this is something that would be added to the code so that the proper number of zeroes would automatically input into the custom property?
AMCBridge eXperts Mar 14, 2010 6:07 AM (in response to Aaron Larson)Here is the small sample how to format the number depending of decimal places count. You should pass the model's doc pointer to the
RoundToDecPlaces function and the value you would like to format. Is it what are you looking for?
Dim roundVal As String
roundVal = RoundToDecPlaces(swApp.ActiveDoc, 40)
Function RoundToDecPlaces(swModel As SldWorks.ModelDoc2, val As Double) As String
Dim decPlaces As Integer
Dim retVal As String
decPlaces = swModel.Extension.GetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swDetailingLinearDimPrecision, swUserPreferenceOption_e.swDetailingDimension)
retVal = FormatNumber(val, decPlaces)
End Function
