Why is there not a sellect/desellect all function for the state change and/or any other window that shows the document tree? We have chosen not to put all the assemblies and parts into the work flow. When trying to move items through our workflow we have to manually uncheck all the documents.
As an aside, should I just remove the .sldprt and .sldasm from my cad files category for the work flow which would only have .slddrw. would this keep the supporting documents from going through?
There is a select all... right click in the dialog and you'll see the command shortcuts.
As for your other question, as long as the .sldprt/asm files have another category to fall into, yes. The bottom line is that you need to tell the system where you want files to go. It can't guess.
