We have to move the SolidWorks license server to a new machine because of hardware problems.
The current server has a USB key device on it and I assume that needs to be moved to the new server. I also have a .lic file.
The question I have is do I just need to plug in the USB dongle, then start the install and give it the .lic file when it asks and it will install the license server?
Do I need to get a new license file, or enter any information or is it all pulled from the USB dongle?
Any help would be appreciated. Thank you.
Mike,
You should confirm this with your VAR, but I believe your license file is keyed to the MAC address of the machine it is currently running on. If you just move the dongle, license file, and install FlexLM on the new server I think the mismatch of the new machines MAC address will still keep the license from functioning. Your VAR can can get you an updated license file if you provide the new MAC and if you push a little they can usually get one back to you in a matter hours.
Daen
