8 Replies Latest reply on Jun 29, 2010 8:20 AM by 1-S3OCKE
    Get points from spline
    saar beno
      i am using solidworks 2010.
      i have spline that is function x(t),y(t),t0,t1, i am drawing him with the function:
      partdoc.skethmanager.createequationspline2(x(t),y(t),t0,t1) (this function work only in solidworks 2010)
      this function return :Iskethspline
      now i need to get points from this spline but i want to get avery some delta (like 0.5 mm) xyz point.
      thanks for the help.
        • Re: Get points from spline
          AMCBridge eXperts
          Dim swSkSpline As SldWorks.SketchSegment
          Dim swCurve As SldWorks.Curve
              Set swModel = swApp.ActiveDoc
              Set swSkSpline = swSelMgr.GetSelectedObject6(1, -1)
              Set swCurve = swSkSpline.GetCurve
              Dim swSkSpl As SldWorks.SketchSpline
              Set swSkSpl = swSkSpline
              Dim vEndPts As Variant
              vEndPts = swSkSpl.GetPoints2()
              Dim vStartPt As Variant
              Dim vEndPt As Variant
              vStartPt = Array(vEndPts(0).X, vEndPts(0).Y, vEndPts(0).Z)
              vEndPt = Array(vEndPts(1).X, vEndPts(1).Y, vEndPts(1).Z)
              Dim vPoints As Variant
              vPoints = swCurve.GetTessPts(0.0000001, 0.0000002, vStartPt, vEndPt)
              Dim i As Integer
              swModel.SketchManager.Insert3DSketch True
              swModel.SketchManager.AddToDB = True
              For i = 0 To UBound(vPoints) Step 3
                  swModel.SketchManager.CreatePoint vPoints(i), vPoints(i + 1), vPoints(i + 2)
              Next
              swModel.SketchManager.AddToDB = False
              saar beno
              i know this macro this not so good for me.
              i want to declere the delta between every point that i get
                  AMCBridge eXperts
                  Try to evaluate the spline's curve with number of derivative == 1 (X, Y and Z).
                  Find the ratio of required chord length to overal curve size. And use this ratio multipied on UParams (usually from 0 to 1) of the curve while passing the parameters to ICurve::Evaluate2 method.
                  Please let me know if you need more clarifications on this issue.
                      saar beno
                      hy,
                      i'm sorry but i dont understand what i need to do.
                      again i have a spline that i get from the function "partdoc.skethmanager.createequationspline2"
                      and i want to get points of x,y,z from him many as i wish.
                      thanks allow fot the help!!
                          saar beno
                          thanks allot for the help**
                              AMCBridge eXperts
                              Here is what I mean. This macro allows to split a spline by specifying the chord length. It is also possible to rewrite the macro to specify the number of points.
                              Dim swSketchSeg As SldWorks.SketchSegment
                                  Set swSketchSeg = swSelMgr.GetSelectedObject6(1, -1)
                                  Set swCurve = swSketchSeg.GetCurve
                                  Dim vPts As Variant
                                  vPts = SplitCurveByChord(swCurve, 0.05)
                                  swModel.ClearSelection2 True
                                  Dim i As Integer
                                  For i = 0 To (UBound(vPts) + 1) / 3 - 1
                                      swModel.SketchManager.CreatePoint vPts(i * 3), vPts(i * 3 + 1), vPts(i * 3 + 2)
                                  Next
                              Function SplitCurveByChord(swCurve As SldWorks.Curve, chordLength As Double) As Variant
                                  Dim swCurveSpline As SldWorks.Curve
                                  Dim nStartParam As Double
                                  Dim nEndParam As Double
                                  Dim bIsClosed As Boolean
                                  Dim bIsPeriodic As Boolean
                                  Dim incr As Double
                                  Dim i As Integer
                                  Dim vParam As Variant
                                  Dim retVal() As Double
                                  swCurve.GetEndParams nStartParam, nEndParam, bIsClosed, bIsPeriodic
                                  Dim curveLength As Double
                                  curveLength = swCurve.GetLength3(nStartParam, nEndParam)
                                  ReDim retVal(CInt(curveLength / chordLength) * 3 - 1)
                                  incr = (nEndParam - nStartParam) / (curveLength / chordLength)
                                  For i = 0 To (UBound(retVal) + 1) / 3 - 1
                                      vParam = swCurve.Evaluate2(nStartParam + i * incr, 1)
                                      retVal(i * 3) = vParam(0)
                                      retVal(i * 3 + 1) = vParam(1)
                                      retVal(i * 3 + 2) = vParam(2)
                                  Next
                                  SplitCurveByChord = retVal
                              End Function
