I was just hired by a start-up company that is in the process of setting up a new engineering venture. The company has three standard seats of SW2008 with the future goal of upgrading to SW Professional and use PDM workgroup to manage the parts, assemblies, drawings, and documents. Unfortunatelly, nobody in the company has worked with PDM before and we belive that it is important to proceed with early configuration management practices to avoid costly mistakes in the future. Therefore, I would appreciate if any experienced poeple in PDM workgroup can provide me with some guidence in respect to things we should establish now prior to make mistakes than can give us problems once we move to a Vault. Just to provide a start on what type of info we are looking for i am going to make some questions to bring people to write their comments:
1. Part Numbering scheme - Will PDM workgroup have problems with alpha characters, dash values, or other characters for part numbers? Should files be named with the part number and use custom properties to add other important information? or the file name is irrelevant?
2. How PDM workgroup treats configurations - I have read that PDM won't recognize configurations as different parts, if so should we start creating individual files for each part config. or are there ways around this problem?
3. How does PDM treat parts unders a diferent project names?
4. Is there an specific folder structure needed?
5. Which custom property information is relevant and important to PDM?
6. Connectivity to ERP software?
7. Accessing the vault off-site??
7. What else should i be aware of!!! DO's and DONT's
Well I hope i can get some good information that can help us avoid a costly and great headache in the future when moving to PDMworks.
-A
1. File names can be anything allowed by Windows. The file name becomes relevant when sending out to vendors, so using the part number for filename is the preferred practice. You can start off with names and once an assembly/parts is ready to assign a number checkin latest versions and rename inside vault. This will preserve any in-context relationships. Make sure to remove named versions from local workspace.
PDMW has an option to not display the filename (labels). This allows for instant recognition of any document without a number property filled in, assuming you are displaying the number property label in the vault.
2. True and yes. PDMW cannot manage configurations to represent different part numbers within one document.
3. One filename per vault is allowed, no duplicates. The projects in the Vault do not behave like folders in Windows. There are no real walls. The projects are just organizational and performance tools.
4. No, but beware renaming a project is not allowed. Also, no duplicates for projects, this is a "REAL" annoyance.
5. The decision is yours however, you cannot force properties to be filled out.
6. Not realistically possible. PDMW is a closed database. Even if it was "open" the big drawback is that only SolidWorks files are listed with a quantity in reporting window, assuming you export the BOM from the Vault. Generics are only considered as an "attachment". Not only is this an annoyance it's a major drawback. You might have more luck going straight from SolidWorks to ERP but, there again, no generics would make the trip which could possibly make the BOM incomplete.
7. VPN
Workgroup is a very basic and simple system. Your choices and options are rather limited. Get it up and running and experiment a little.
hth
