By the time I finished making "explode view" on the assembly and when I want to add "line sketch explode", there is a little problem that I do not know. When I click OK on the Route Line dialog box, and then I click Exit Sketch, appeared dialog box "This operation requires a fully defined sketch". So I can not see the results of the line sketch. But I just can 'exit sketch', when the line sketch that I have turned into 'fix' on add relations. Please be explained about this. Is the way this is so or there is another explanation?
I seem to remember once having a similar problem because I had an option turned on, which insists that every single sketch you make is fully defined or it will not let you exit the sketch. Normally it is fine to remind you to fully define everything, but sometimes it makes more trouble than it helps...
Do you by any chance have "Use fully defined sketches" turned on in the options?
(In SW2010: Tools > Options... > System Options > Sketch)
