Distance mate in SW VB add-in
Question asked by Karl-Gustav Johansson on Jan 29, 2010
Latest reply on Feb 10, 2010 by Karl-Gustav Johansson
I've created an add-in for SW in VB.net and it can move a sub assembly and also change one of the subassemblys distance mates.
The thing is that I want the add-in to be able to do this in realtime To move the subassembly goes realy fast but as soon as I call the edit distance mate function everything goes very slow even on a fast computer. Anyone has any ideas how to improve the performance or another approach that can give the same result? I am using SW 2008 SP5.
Here is the function I use to change the distance mate in the sub assembly with.
As you can see its pretty much from the example in SW API help with just the difference that it goes into edit assembly mode before changing the mate.
Function changeDistanceMate(ByVal matePart As String, ByVal distanceValue As Double)
Dim swFeat As SldWorks.Feature
Dim swMate As SldWorks.Mate2
Dim swDispDim As SldWorks.DisplayDimension
Dim nNumMateEnt As Long
Dim swMateEnt() As SldWorks.MateEntity2
Dim vMateEntPar As Object
Dim nRetVal As Long
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swFeatMgr As SldWorks.FeatureManager
Dim swModelView As SldWorks.ModelView
swModel = swApp.ActiveDoc
swModelView = swModel.ActiveView
swFeatMgr = swModel.FeatureManager
swAssy = swModel
swConfigMgr = swModel.ConfigurationManager
swModel.SetAddToDB(
True)
swModel.SetDisplayWhenAdded(
False)
swModelView.EnableGraphicsUpdate =
False
swFeatMgr.EnableFeatureTree =
False
swFeatMgr.EnableFeatureTreeWindow =
False
'Set swApp = Application.SldWorks
'Set Part = swApp.ActiveDoc
'Set SelMgr = Part.SelectionManager
boolstatus = Part.Extension.SelectByID2(
"robot-1@visualisering", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
Part.EditAssembly()
Part.ClearSelection2(
True)
boolstatus = Part.Extension.SelectByID2(matePart,
"MATE", 0, 0, 0, False, 0, Nothing, 0)
'boolstatus = Part.Extension.SelectByID2("distanceMate2@robot-1@visualisering", "MATE", 0, 0, 0, False, 0, Nothing, 0)
swSelMgr = swModel.SelectionManager
swFeat = swSelMgr.GetSelectedObject5(1)
swMate = swFeat.GetSpecificFeature2
swDispDim = swMate.DisplayDimension2(0)
nNumMateEnt = swMate.GetMateEntityCount
ReDim swMateEnt(nNumMateEnt)
For i = 0 To nNumMateEnt - 1
swMateEnt(i) = swMate.MateEntity(i)
swComp = swMateEnt(i).ReferenceComponent
vMateEntPar = swMateEnt(i).EntityParams
Next i
Select Case swMate.Type
' Cannot change alignment on these mate types
Case 10
Exit Function
End Select
swModel.ClearSelection2(
True)
' AssemblyDoc::EditMate2 requires mate entities
' to be selected with mark of 1 except for:
' swMateCAMFOLLOWER
' cam face --> 1
' cam follower face --> 8
' swMateSYMMETRIC
' symmetry faces --> 1
' symmetry plane --> 4
bRet = SelectMateEntity(swApp, swModel, swMateEnt(i), 1) : Debug.Assert(bRet)
Next i
' AssemblyDoc::EditMate2 requires mate feature to be last selected object
' mark is ignored
'swMateAlignCLOSEST
bRet = swFeat.Select2(
True, 0) : Debug.Assert(bRet)
swAssy.EditMate2( _
5, _
2, _
False, _
distanceValue, _
distanceValue, _
distanceValue, _
0.0#, _
0.0#, _
0, _
0, _
0, nRetVal)
' Do not assert because may overdefine assembly or other error
'Debug.Assert swAddMateError_NoError = nRetVal
' Do not assert because assemlby may have rebuild errors
' due to changing mate alignment
Part.EditAssembly()
'Part.ClearSelection2(True)
'bRet = swModel.EditRebuild3: 'Debug.Assert bRet
True)
swModel.SetAddToDB(
False)
True
True
True
End Function
