I'm trying to set the size of a tapped hole in a design table but the dropdownlist did'nt work.
What goes wrong ?
I like to control all the data from the tapped hole in the table like bore depth, thread depth etc.
How get it into the design table ?
SW Professional 2010 SP2.0
Greetings !
I've never been able to control anything more than the nominal Tap size. I'm yet to work out if it's possible to bring in the other dimensional info (drill / tap depth) associated with a hole-wiz feature.I cant imagine why you would'nt need this the rest of this information. Tap size alone is pretty useless.
I usually give up and create a hole from scratch with each dimension manually brought into the table. Anyone else here that knows this is done ?
The thread below went part way into answering some questions but not what you an I are looking for, a way to simply control HW depths vis the design table. Without stuffing around with standards.
https://forum.solidworks.com/message/116913#116913
