Am I the only one who got serious problem with Routing since upgrading to 2010? I'm not able anymore to get decent flatten route for simple cable assemblies, I've got a lot of error appears in routing assemblies without reason, some virtual parts appear into my cable assemblies that distort all cables, and so on...
Another example, if I create a cable in an assembly, no problem. When I take this assembly and insert it in another assembly, all my cable assemblies return me error and all the wire are no more defined and it's not possible to fix the problem.
I feel like they add a bunch of bugs in 2010 version and this compromise a lot of our project. I never get this kind of problem with 2009. If someone can help me with that or give me any clue about what could be the problem, I will appreciate.
thanks a lot.
I am no routing expert but I have had some difficulty in routing flexible tubes since upgrading to 2010sp0 & sp2, errors when I open an assembly and I always have to save even if I don't change anything. I know this doesn't help but at least you know you are not the only one having problems.
Cam
