I am dealing with embedded circuit boards with a few hundred components in my main assembly. When I try to run the interference detection on the complete assembly it flags thousands of interferers, mostly at the component level on the circuit boards. If I check the "Treat subassemblies as components", the detector seems to ignore the setting as if it can't determine the internal subassemblies at all. If I check the box, then select all of the individual parts and subassemblies I don't get thousands of errors, but I do get a few hundred that are still limited exclusively to the circuit board subassemblies (electrical components that interfere with the circuit board itself, which I don't care about).
Can anyone else verify this problem? I may be able to upload some sample circuit boards, if that would help.
I am working with SW2010 on Windows 7, NVIDIA's w/ proper drivers, 16GB of RAM.
I don't have that one checked, that would cause even more errors.
Thanks though.
