I had at least 2 instrances in an assembly when mates where broken using hole cylidrical surface after adjusting the hole size.
Is this a normal behavior?
If you Just changed the hole size and not the hole type, that is not normal behaviour.
Was a chamfer added?
Did you apply the mates individually, or using the Alt select edge method?
