1) Make 3 configurations of the hinge assembly. (flex 1, flex 2, flex 3)
2) Make sure the hinge assembly IS flexible.
3) Set each hinge assembly in the upper level assembly to a different flex configuration.
That's the easiest way I have found to deal with simulating moving hinges.
Hi
I have same problem, I build a hinge assembly with a hinge mate, and bring to another assembly and mate with another parts or assembly, and hinge not want work, looks like one fix component, I cant understand from this discusion what need change, can You explain me, what to do, pls, thanks
zcsaba
Zcsaba,
Hello and welcome to the forum.
Sub-assemblies brought into another assembly will be fixed. RMB on your sub-assembly in the FeatureManager Tree and go to Properties and choose "make assembly flexible". I am at home and don't have SW here so am not sure about the exact wording. You can also do a search here on flexible sub-assemblies.
Hello Gleen
Thank you, after were I write my post, I find configuration, but now I have another trouble, like Mohamed, two or more hinges not want work together, try here writed solution, may be will work on mine
again thanks
Zcsaba
Hi
Again me, I attach archived file with parts and assembly, I can't configure mate, hinge work right still not using in another, I use angle mate, but when I put to next assembly, jump to next side, still working beetween angle 0 deg - 90 deg, but turn to outside, hinge is work correct, but in test assembly isn't, can somebody solve this problem? or explain what I must to do. pls
zcsaba
Right Click on the Fixed Bolt and "Fix" it. this will anchor your assembly around the bolt.
Then remove your 3 coincident plane mates of the first hinge sheet (coincident 13, 14, 19)
