Dear All,
This is really has to do with a fundamental design approach adopted in the modeling and designing of sheetmetal parts.
I'm really interested in knowing about the experience and method used in designing of the parts.
I kind of liken it surface and solid modelling .
Using the sheetmetal tools really is building the part face by face like in surface modelling . Slow but has its own
benefits that the flattening can be ensured after each new sheetmetal feature is added. Also allows for some complex
corner matching etc to be performed interactively like with mitre etc.
Really it boils down to what method you really are more comfortable with and the level of parametric capability that
you ultimately want to build.
It also has to do with the confidence of being able to flatten the geometry created successfully at the end of unconventional
loop of not starting the modelling as sheetmetal.
Hope I really get a few examples and ideas and interesting methods employed by people using sheetmetal in so
many different ways .
Pankaj Bir
For me it's probably 50% of the time I use sheetmetal.
Most of my uses are guarding and chutes, usually for clearance reasons it's easiest to start with a block and carve corners off etc until I have the shape that I need. Then once I have the solid it is shelled and converted to sheetmetal.
For cone segments and rolled plates I usually loft, for simple parts I just create from sheetmetal bends upwards.
I have found that converting from a solid often gives corner details that are not what I want. Creating the same part as sheetmetal gives me more control over these.
