8 Replies Latest reply on May 5, 2011 3:08 PM by Adam Lanners
    PDF Creation on Check-in
    Mike Ramsey
      Is there a way to set EPDM to create a PDF everytime you check the file in?
        • Re: PDF Creation on Check-in
          Daniel Tuczapski
          Hi
          I'm quite sure then there is no such functionality but you could do an automatic workflow step which is performed on the the transition and it trigger task to generate PDF file
          cya
          Daniel
            Are you using EPDM 2010?  I believe you can use the new task feature to do just that. I just installed 2010 yesterday but I plan on trying this out in the next day or two and see how the Convert Task works.  If you are using EPDM 2009 or older then there is no feature that I know of that will do this.  You have to write custom code to handle this instead.
            You can read about Tasks in Chapter 20 starting at page 213 of the EPDM 2010 Administration Guide
                Mike Ramsey
                I'm running 2010 but I'm not sure that tasks will do it. I know they will do it when I change workflow state but I don't think it will do it everytime I check a drawing back in.
                    Calvin Nelson
                    You're right, that tasks are not directly accessible from the Check In/ Check Out process. However, you could use the code generated by a task to help create an executable that is kicked off thru Dispatch at Check In.
                    Dispatch would definitely be the starting point you want to use, unless you can write your own add-in.
                    May your solution be near and complete, not nearly complete.
                    Please, Let us know what you come up with.
                    Calvin
                  Ben Kalinowski
                  You could set-up the pdf to be created through Tasks, and create an inital state with an auto-transition to a second state in your workflow.  The auto-transition kicks off the pdf, and since it happens automatically, users don't even realize the transition happened.
                  Good luck.
                    Adam Lanners
                    We do this currently in PDMWorkgroup. However, it is not easily doable in EPDM.
                    The only method that I know of is to create an add-in that has a hook to the post check-in Command Type which would then run and generate a PDF of the file being checked-in.
                    I would warn you though, that this should not be done without considering the ramifications. Creating a program that hooks into every file check-in could seriously bog down your user experience.
                    If you are doing this because of how it works in Workgroup I would take a step back and reconsider if it is absolutely necessary to have a PDF generated on check-in. Our comany went through the same thought process and found that it wasn't exactly necessary but nice.
                    Hope this helps.
