Adding sheetmetal to weldments
Question asked by Duane Roberts on Jan 13, 2010
Latest reply on Jan 18, 2010 by Duane Roberts
I have a cart assembly that I have made with weldments everything is great, except I need to add some skin to it and a shelf.  Is there a way to add these to reflect in the cut list or do I just have to make each part a separate sheet metal part?  I added a sheet metal part to the bottom shelf and that came out in the cut list but I have not been able to add more sheet metal I wish I could so I would not have to keep going into my BOM and adding stuff.  Here is a copy of the part with out the skin, and you will see the second shelf will be an extrude that I had to make, that if I cannot find a solution will have to manually add in BOM and possibly remove completely and make an sheet metal part and create and assembly.
