When I create a part, I use the custom properties to fill in the following:
part no.
description.
material.
I use them to fill in the title block of my drawing.
When I need to create a similar part to the original I use the 'save as..' function. This results in copying the custom properties too...
Offcourse the new part needs to get a new 'part no.', 'description' etc.
Is there a way to blank out the property values or to return the values to template settings.
Peter did you checked the modified macro in my above post Re: blank out values in custom properties
