I'm not sure if I'm the first to notice this, but when you check in a sheet metal part that has a material assigned to it, there is a greyed out "Cut-List-Item1" underneath the part file. Oddly enough, when you first make a sheet metal part and try to check it in, there's no problems - it only happens when you assign the material property.
Has this been reported?
brian
Hello Brian-
In 2010, sheetmetal parts now have cut list items, see the What's New Guide, so this should be normal behavior, right?
I'm not sitting in front of a 2010 machine right now.
Devon Sowell
http://www.3-ddesignsolutions.com
http://www.pdmsolution.com
