Hi all,
I am just wondering what is the best way to created a top down assembly so that I can have it set-up so I can change certain parameters and save it as a seperate file so that I can then make different changes to the template to create a totally new file without affecting the previously made file?
for example:
Template door frame----> Job number 001
-----> Job Number 002
Its just to save time as only certain dimensions change and it doesnt make sense creating a new door frame from the ground up, but so far with the top down assemblies I have made I make changes and save it as a seperate file, yet whenever I make a change to the original assembly all the other assemblies are still affected because all the components are still linked.
Any help is greatly appreciated
Cheers
Craig
I take it you have an assembly containing a number of parts that you need to use as a kind of template for other models. For this to work you need to create a new assembly and new parts that are referenced by the new assembly. If you just create a new assembly it will still reference the old parts. When you change the old part the new assembly will change as you have found.
