If a part or surface is set to transparent via the RMB menu, the FM option does not reset it to solid ... and vice versa. The two functions appear to operate independently. Is this intended? If so, why?
Can you explain better does not reset it to solid ?
I see that are aligned.
I use SW2010 SP1
