Has anyone had any luck in having parts modeled in solidworks use different origins than that used in the ECAD software? The help files for circuitworks state that if you put a lone sketch point in the component outline of the 3d model, that circuitworks should use that origin. I have added the sketch point to the 3d model of the part and circuitworks appear to recognize that the part "moved", but then that change is not applied to the solidworks assembly when I build the model.
What am I missing?
Any advice would be appreciated...thanks!
After working with my local support rep, it appears as this is not a supported feature at this time.
The work around is to use the move/copy body to match up the part model with the ECAD origin. The only thing I don't really like about this is that if you have any sketches visible in the part, they are not moved with the part. Any one know a way around that?
Thanks-
