Hello everybody, a newbie has arrived, don't be very hard with me
I have just installed SW 2010 and SP1.0. Everything seemed OK, but I've opened some 2009 assemblies I designed and I'm starting to get some errors showing/hiding some solids of a multisolid part.
There are some strange things like for example, the solid isn't hidden, but can't see it. If I move the mouse over the place the solid should be, it highlights it's elements. No matter how many times I try to hide or show it, I still can't see it (Also tried Ctrl-Q).
Other thing for example is that the solid isn't hidden and I can see it, then I try to hide it but nothing happens. And it's not happening with all the solids of the part, just with one of them.
Another one is that the solid has one color, but when I select a section view, it changes its color.
Did it happen to anybody else? Is this a known bug or something?
Thanks a lot.
Iñaki B.
I have the same issue. It was reported to SW and they were able to re-create it. I am using an approved video card and driver.
The issue with my particular model was a mirror feature at the bottom of the feature tree. The work around was to un-merge the mirror and then use a combine feature to join it back to the part. I now have another model doing the same thing but this time it is after a scale feature high in the tree. I fixed it by rolling up the tree until the part showed. This will isolate the feature causing the problem. Then re-create the offending feature and delete the old one.
SW2010 is super buggy. They need to fix this fast.
This is the response from SW:
You will be notified when SPR 524372 is addressed. Thank you for bringing this issue to our attention.
Jeff
