I have two part files and would like to make mate between them.
The mate which I would to make is: The first part file moves then meets another part file and then two part files move together.
How I can make this mate?
Thanks in advance!
Thanks a lot for your quick reply.
When the first part file performs circular movement, another part file performs linear movement should I use limit mate again?
When the two part file perform circular movement should I use limit mate?
Rack & Pinion mate? Screw mate?
Gear mate?
Give these a try.
