We are having trouble using the derived pattern, because it does not pattern the correct amount of components. In the part we create a linear pattern, then create a derived pattern in the assembly. The derived pattern has a mind of its own, some of the configurations come out ok, some do not. If I open the part where the referenced pattern is located, then go back to the assembly the derived pattern corrects it self. FYI - We use PMD workgroup
Any help would be great.
- Thank you
I have seen similar behavior when the part with the driving pattern is lightweight - the derived pattern won't update correctly untill the part is resolved (wich would happen when you opened it). though I don't see any light weight symbols in your screen shot....
maybe it has something to do with the driving part being in a sub-assembly? I'll see if I can ty that out today.
Jeremy
edit: tried it with a simple sub-assembly - it seemed to work with no issues (2010 sp1.0)
