Can I bend a portion of a flange end along a sketched bend line? (picture attached in Word document as I could not get the sketched line to show in jpg saved from SW) SW2006. I know one way to do this is to cut out and use edge flange but just curious to see if it can be done differently.
If you want one bend then you wont use jog (it makes two bends), you need to cut the edges then bend the flange.
Dear Ghazi,
Change the sketch of the first edge flange and simply model an edge flange. Its faster and more flexible .
See the attached file.
Pankaj Bir
Thanks Pankaj. I understand your suggestion. I forgot to mention I use SW2006 so could not open the attachment.
