When creating properties for your cut list in your part, you can insert values that will automatically update themselves.
1. Right click your folder in your cut list (part mode)
2. Select length for your property. If length is already a property you can create another length property under a different name. (ex: Length 2)
3. Move your window to the side so you can select items in your graphics area and double-click the item that you want the length of. This should show all of the dimensions of your feature and sketch.
4. With your curser in the Value/Text Expression field of your cut list, double click the dimension you want to show and it will automatically populate that field. You can put dimensions on your model and select those dimensions also.
Hi Biren,
Hope this helps.
