Hi All,
I use the flatpattern export feature extensively to create DXF files for a vendor's CNC plasma table. I have a copy of the CNC software and so I design the part in SW, export the flat pattern to DXF, import this DXF into the CNC software and then finish preparing the CNC cut file by indicating the path cutting details. I have started including text communicating the part number, the part description, and the material the part is to be cut from as helpful information to the machine operator. This text is excluded from the cut path info. What I would like is a way to have SW place this text in the flatpattern DXF from custom properties already in the part model. Do any of you have an idea how this could be done?
Dear Kevin,
Sure you can do it.
I hope you are using Solidworks 2010 .
One way of achieving what you want to do is to add the info to the custom property cell.
Then create a sketch using one of the faces of the part. The sketch can include text geometry linked to the
desired custom property.
While exporting ensure to pick export sketch option.
This could form your template file to be used over and over again.
Bingo the custom property info is exported as well.
Alternatively give meaningful names to your part file with extensions that include material name thickness - just a thought.
If you place the text well you could even laser etch or punch the info on the part being cut for easy identification of the blank.
Pankaj Bir
PS See the attached file
