Config or design and How ?
Question asked by Martin Hall on Dec 27, 2009
Latest reply on Dec 28, 2009 by Martin Hall
Hi,This is my first post and I'm new to solidworks,so thanks for your help in advance.
I am trying to create a label made from 2 part plastic.I have created the lower portion which is white and then the top portion which is blue.In reality when I engrave text through the top surface I will end up with a blue label with white writing.I have created the text and extruded through the blue to show this but when I change the text in the next configuration they all change to the updated text.My question is this,I have 14 labels to do and originally thought that I could create a design table containing the text but I have found that this is not so (with my limited knowledge),I think my only option is to create a default configuration and then create the different text and extrusions in the feature manager using a design table to suppress/unsupress the desired values.Am I approaching this in the correct way ? File attached
Martin
