We use a combination of AutoCAD and SolidWorks drawings and we seem to have the problem of our description becoming misaligned in our autocad files. I have checked the templates numerous times and tried adjusting the block to make sure the description is centered but it will still move around on the paper space. There doesnt seem to be any pattern to the misalignment. Sometimes it will be left, or right, sometimes high or low. I have attached a screen shot as an example of what we are seeing. Just wondering if anyone else is seeing this problem
The insertion point is on the lower left hand corner
The template was created by us with existing text packages and is only used by us.
simple " DON'T USE AUTOCAD" again it's 2 different can packages doing the same thing differently, how they handle fonts is always fun.
sorry just a little fun...isn't that what a tech guy would tell you, had the same thing happen in the cam package, any cutter bigger than an 1/8 ball failed...and they say the use the 1/8 ball.....
merry xmas
