I'm working with SW2008 SP0.0. When making Edge-Flange and then I click OK, the looks are Rebuild Error message! What is wrong in this operation? Please help. Thanks
I have tried but still can not. But on the other side, when I use other commands such as making Hem, there was no problem. This means that successful when I click OK. So what about that makes up the message "This operation requires a fully define sketch" when I click OK on the Edge Flange command? Thanks
Mr. Deepak, the above problem seems to answer exactly the same as the answer at tread https://forum.solidworks.com/message/141913#141913. Not use option of "Use fully defined sketches" at Tools > Options > System Options > Sketch. And finally I succeeded to make Edge-Flange
Langgeng, I never use that option and that might be the reason I'm not getting any error for edge flange or explode line
Thanks for sharing/updating it
