I'm looking for help with a path mate.
The yellow block should follow the cam slot. I've created a composit curve down the centerline of the slot and a point where the center of the roller should be.
I can sellect the the curve as a path but it onle selects a line or a curve even though it's a composit curve. If I move the mechine it will follow on;y part of the path.
As the bean shaped cam rotates. The yellow block moves forward and back. The yellow block should then travel side to side.
I removed the composit curve and selected the cam centerline sketch. I had to use the selection manager.
Now the motion is correct when draging the bean shaped cam around.
I've added a motor to the cam to rotate it. But it oscilates rather about 180 degree rather then just rotates in one direction. How do I get it to just rotate. The motor motion is set to constant speed 5 rpm.
