Simple surface, head fit
Question asked by Jason Aspinall on Dec 14, 2009
Latest reply on Dec 14, 2009 by Jason Aspinall
Ok, what I'm trying to do here is use the sketch on the top plane to remove material from the concave face outwards, leaving a 1mm rim around the window to it can be mounted in a case.
I've tried using a cut-extrude reversing the offset and choosing the side to cut.  Unfortunately, the only option is "through all", which is not what I want to achieve.  I need make a 1mm deep cut outwards...
If the piece part was flat, clearly this would be a simple planar face cut extrude...because the part is bent like a banana, it's giving me grief!
Either I need more sleep or more caffeine...my brain isn't working today and can't see the wood for the trees to solve this issue :/
Message was edited by: Jason Aspinall
