Can anyone else Confirm this? In the assembly feature tree, you can filter components by typing in keywords that pertain to that component.
2010 Sp1
Win xp - x64
Don
2010 Sp1
Win xp - x64
Don
Don -
I am seeing the same. The filter works in the FMT, but checking "Filter Graphics View" makes no difference in the Graphics window.
Win 7 x64, 2010SP1.0
Steve R.
Thanks Steve, I'm seeing the same behaviour and it looks like a bug. I kinda wish I stayed at SP0 now, at least those bugs didn't seem to effect me.
Don
Don -
OK, this is strange.....
Yesterday, I installed SP1 at home. That's where I was seeing (or rather, NOT seeing) the filter applied in the graphics area bug as you described.
I just now updated my SolidWorks here at work to SP1.0.
The filter works fine.
Both systems Win 7 x64. My home system, however, has an ATI game card in it (no Realview), and my work machine has an FX3450....
I know what registry settings are.... but I have no idea which setting you are reffering to that needs renaming.
Don
rename HKEY_CURRENT_USER\Software\SolidWorks with SolidWorks closed and restart after.
If the problem is resolved...you have lost your setting and need to delete your renamed registry...if not...cancel the new registry and rename the renamed to the original name...always does this operation with SW closed.
Suerte...
I can't help you directly, but on SW2010 SP1.0 on 32bit it works fine.
Maybe you have a SW registry corrupted.
Try to rename it.
